stiassny_88246's avatar
stiassny_88246
Aug 22, 2011
Help with iRule on LinkController
Hey. i want to use this iRule in my LinkController. I want to rule to check if the client that try to go through the machine is from ip address 192.168.1.11 or 192.168.1.10 and if it tries to access the following URL: "http://www.specific-domain.co.il/sub.address/somepage.php" then it will be directed to a pool called HTTP_pool. when i try to save the iRule i get to following message: line 1: [ltm_rule_L7 feature not licensed] [when HTTP_REQUEST { line 6: [ltm_rule_L7 feature not licensed] [HTTP::host] line 6: [ltm_rule_L7 feature not licensed] [HTTP::uri] line 7: [ltm_rule_L7 feature not licensed] [HTTP::host] line 7: [ltm_rule_L7 feature not licensed] [HTTP::uri] when HTTP_REQUEST { set clientip [IP::client_addr] set pool "HTTP_pool" set httphost "www.specific-domain.co.il" set base_uri "/sub.address/somepage.php" log "Request: [HTTP::host][HTTP::uri] from [IP::client_addr]" if {([$clientip equals 192.168.1.11] or [$clientip equals 192.168.1.10]) and ([HTTP::host] contains "$httphost") and ([HTTP::uri] contains "$base_url")} { pool $pool } }} Please Assist. Thanks.
