Mr_Moody's avatar
Mr_Moody
Sep 22, 2020
Help with irule for bypassing client authentication certificates by IP
Hello, I'm looking for help with an irule that will bypass the client authentication certificate for a group of ip addresses. Currently we have the client cert auth working with a client ssl profile in LTM set to require client authentication. We would like to allow certain IP addresses access to the site without client certificates.
I assume that I would need to change the ssl profile to 'request' client auth and create an irule to handle things from there. I think the logic should be something to the affect:
if ip is in data group list of IP addresses->allow access without cert
request client certificate->if valid cert presented->allow access
If no cert and not on list->deny access
Any help would be appreciated.
  • Hi
    You could create a second SSL profile that doesn't require client auth and then use this profile for specific IPs. There's an example here on clouddocs
  • Thank you for the response. Your answer helped me end up with the below. The key was that the ssl profile assigned to the VS had to be set to ignore.
      if {[HTTP::uri] starts_with "/uri1" || [HTTP::uri] starts_with "/uri2"} {
       if {not [matchclass [IP::remote_addr] equals NOCERT_IP_LIST]} {
        SSL::session invalidate
        SSL::authenticate always
        SSL::authenticate depth 9
        SSL::cert mode require
        set cmd "SSL::profile /Common/require_clientssl"
        eval $cmd
        SSL::renegotiate
        event disable all
