Gill_32697's avatar
Gill_32697
Nov 16, 2012
help with irule else test-pool not getting hits
When typing only https://test.swbc.com in my browser I am not hitting my last resort pool Test-SWBC-Migration2
I do get out current home page but not the new website on pool Test-SWBC-Migration2. Please check why my else pool Test-SWBC-Migration2 my not be showing.
Also, how can I add a logging statements to the irule that will show me the pool im hitting and the command to view in the ssh shell.
if { ([string tolower [HTTP::host]]) contains "test.swbc.com" } {
switch -glob -- [string tolower [HTTP::uri]] {
"*paymentprocessorv3*" -
"*paymentprocessorakc*"
pool IIS_ECM.SWBC.com_pool
"/holtcat" {
HTTP::redirect "https://focusnet.swbc.com/fnFProvider/fnFProvider.asp? app=HCEnrollmentTool&wanted=BECONFIRM&BenefitYear=2011&BenefitType=N"
"*/akcelerant*" -
"*/idsakcelerant*" -
"*/idsakcelerantmtg*" -
"*/lmakcelerant*" {
pool IIS_SWBC.com_pool
else {
  • The else statement in your iRule is being used as a case in the switch.
    If you want to use an "else" type case for a switch, use the keyword "default" instead of "else" (see the default wiki topic: https://devcentral.f5.com/wiki/irules.switch.ashx).
    If you want it to be an else for the first "if" statement, move it out of the switch.
    Hope this helps...
