help with http::path
Hello i am trying to add logic in to account for different branches of testing in my irule.
currently we adjust the http:path to a particular value
set apiPathStage "apiproxy/apiproxy.aspx"
HTTP::path $apiPathStage
example request may be http://1.2.3.4/interface.asp?Command=testcommand
converts to http://1.2.3.4/apiproxy/apiproxy.aspx?command=testcommand
this works great.
going forward the developers want to be able to add in additional branches to the path such as:
http://1.2.3.4/test/interface.asp?Command=testcommand
http://1.2.3.4/stage/interface.asp?Command=testcommand
http://1.2.3.4/dev/interface.asp?Command=testcommand
I am looking for a way to take the first part of the entered path and insert it before the applied path value.
so that the 3 examples above would generate:
http://1.2.3.4/test/apiproxy/apiproxy.aspx?command=testcommand
http://1.2.3.4/stage/apiproxy/apiproxy.aspx?command=testcommand
http://1.2.3.4/dev/apiproxy/apiproxy.aspx?command=testcommand
any help would be appreciated.
thanks,
Ben
- Andy_McGrath
Cumulonimbus
If you are just trying to map 'interface.asp' to 'apiproxy/apiproxy.aspx' in the HTTP path use the following:
HTTP::path [ string map { "interface.asp" "apiproxy/apiproxy.aspx" } [string tolower HTTP::path] ]This takes the HTTP::path value (converted to lowercase) and does a search for "interface.asp" and replaces it with "apiproxy/apiproxy.aspx" then passes it back as the HTTP::path.
