Help with http to https redirect
Hello,
Grateful for any assistance with the following issue.
We have one VS serving http and https traffic for domain1.org. The redirect from http to https is done via HTTP Class profile:
Local Traffic > Profiles > Protocol > HTTP Class > http2https:
Parent Profile: httpclass
Hosts: Match all
URI Paths: Match all
Headers: Match all
Cookies: Match all
Send To: Redirect to
Redirect to Location: https://[getfield [HTTP::host] ":" 1][HTTP::uri]
This works perfectly fine for domain1.org.
Now we would like to add additional domain: domain2.org, pointing to the same IP address, however there is no SSL certificate deployed for domain2.org. So when users enter http://domain2.org, they are redirected to https://domain2.org, which generates a warning about certificate mismatch. If accepted it redirects to https://domain1.org.
Is there any way to configure a VS to redirect from http://domain2.org to https://domain1.org? Do I need to create a separate VS (with a separate IP for domain2.org)?
Thank you.
- El_Jefe_43496
I would use an iRule to do this - something along these lines : when HTTP_REQUEST { if { [string tolower [HTTP::host]] ends_with ".domain2.org" } { HTTP::redirect "https://www.domain1.org[HTTP::uri]" } }
- nov1ce_120072
Thank you, it worked!
- El_Jefe
- nov1ce_120072
- What_Lies_Bene1
I'm afraid I disagree. I'd modify your class and change it to this;
Redirect to Location: https://domain1.org/[HTTP::uri]
