PeterC_70986
Aug 23, 2012Help with friendly name to FQDN redirect
I am trying to write an irule that will redirect:
It seems simple, but every irule I have tried just causes a loop.
Any help would greatly be appreciated!
- Richard__HarlanHistoric F5 AccountThe iRule should be
HTTP::redirect "https://hostA.domain.com"
The loop is caused by the webserver sending links that point to HTTP://hostA. You can set the HTTP profile to enable rewrite redirects. You can also update the application to pass links that are HTTPS. - PeterC_70986
Thanks Richard. Turns out I was entering the correct irule the whole time, the web developer gave me the wrong site to redirect to.
