Help with F5 SWG and APM (Web Proxy function)
Hi All
I need your help on deploying F5 BIG IP with SWG (Secure Web Gateway) and APM (Access Policy Manager) (i.e. Web Proxy) functionality using forward proxy feature.
Can you please let me know how do I go about doing this?
Thanks in advance
Sunny_s
- Dave_W
Employee
Hello, here is some information on these type of configurations and an iApp that can be used:
https://clouddocs.f5.com/training/community/iam/html/class3/module5/module5.html
- Sunny_s
Thanks for the update Dave.
I have tried to use the guide to deploy F5 BIG-IP as a explicit Forward Web Proxy using the Secure Web Gateway (SWG) but it does not seem to work on my test lab.
Is it possible to skip section of AAA (Create an Active Directory AAA) section and rather do authentication based on the source subnet?
Will appreciate help from all the Pros
- Dave_W
Employee
Hello, I am not sure about that, i suppose you could try and test it. It sounds like more you want to use a Transparent Proxy.
- Sunny_s
Thanks for the update Dave, really appreciate your reply on this.
I have checked the deployment guide and it says that you can allow connection based on the Source IP subnets on APM rather than through AAA (AD servers), but I don't know how to achieve this. 😰
Can anyone please help with SWG and APM deployment on F5 based on IP subnets rather than using AAA (Active Directory servers) for authentication?
Thanks in advance.
- The_Y
Cirrus
I believe you should be able to use an ACL assignment to accomplish what you are looking for
- Sunny_s
Hi
Reaching out to all pros
I need help with deploying F5 using F5 APMthe /SWG (using this article - https://devcentral.f5.com/s/articles/configuring-the-f5-big-ip-as-an-explicit-forward-web-proxy-using-secure-web-gateway-swg-30202).
Using show and tell, I have already tried but the solution isn't working the, I will compensate you for your time/efforts. (can you pls contact me on [email protected]).
