help with a DNS response irule
HI, I'm looking for help with an irule that will be attached to a DNS VIP on a LTM v11.x. Its purpose is to supply a fixed response to a particular client querie, all other queries go to the DNS pool.
so far i have
when DNS_REQUEST {
if
{ [DNS::question name] ends_with "msftncsi.com" }
{ DNS::answer insert "$fqdn. 125.56.204.104"}
else { pool internal-dns }
can anyone help build a proper DNS::answer command line ? appreciate your time, cheers
- kunjan
Try this:
when DNS_REQUEST { set ttl 1800 set A "[DNS::question name]. $ttl [DNS::question class] [DNS::question type]" if { [string tolower [DNS::question name]] ends_with "msftncsi.com" } { DNS::answer insert "$A 125.56.204.104" } else { pool internal-dns } DNS::return } - walou12_113339
thanks kunjan,
i get this error
[ltm_rule_dns_write feature not licensed] [DNS::answer insert "$A 125.56.204.104"]
do you know if there is any way to achieve a similar outcome, without this additional licence ?
