Rakesh_Paliwal_
Aug 12, 2016help to confirm cli to install certificate in ltm box
Is it a right command to install cert & key in ltm box ?
tmsh install sys crypto cert abc.com.nonfips.crt from-local-file /var/tmp/abc.com.crt
tmsh install sys crypto key abc.com.nonfips.key from-local-file /var/tmp/abc.com.key
whay are we using nonfips here ?
- IainThomson85_1
Cumulonimbus
the SOL IainThomson85 links provides the commands and the explanations.
the nofips is just a part of the certificate / key name, don't know where you got your commands from, perhaps your environment uses different names for fips and non fips certs.
