Help setting the mss on the client side conenction with an irule
I am trying to set the mss on the client side connection to different sizes based on source ip. I have read that you cannot choose the TCP profile with an irule but with 11.6 you can use the TCP::setmss option but it doesn't seem to work. I have tried to explore changing things with TCP::option 2 as well with no luck either. Please help.
Here is what I have tried.
when CLIENT_ACCEPTED {
if { [IP::addr [IP::client_addr] equals x.x.x.x] } {
TCP::setmss 1000
I have also tried
- Chris_Grabill_2
I could not get the last irule I have tried in there
when CLIENT_ACCEPTED { if { [IP::addr [IP::client_addr] equals 214.28.41.109] } { TCP::option set 2 1000 all } } - Ed_Summers
CLIENT_ACCEPTED doesn't 'fire' until after the TCP connection has been established (the handshake completed). MSS is advertised as part of the SYN packet from each host - so set before that iRule would go into effect. I'm not sure what iRule event should be used for this - I'm doing a little digging as I'm curious also.
