easyfan_179507
Apr 17, 2015[Help] Persistence Hash and Load Balancing together, Possible?
I know the request sounds weird... But it is true. Here is the thing:
We know that F5 supplied a persistence CARP hash since 10.0.0....
Kevin_Davies_40
Nacreous
Apr 18, 2015Can you show us the contents of the virtual server configuration. This will help us check what is configured.
tmsh list /ltm virtual
easyfan_179507
Apr 19, 2015Hi Kevin, following is the configuration of the VS we talked about:
Status
Availability : available
State : enabled
Reason : The virtual server is available
CMP : disabled
CMP Mode : single-cpu
Destination : 9.112.251.45:9080
Traffic ClientSide Ephemeral General
Bits In 121.8M 0 -
Bits Out 87.6M 0 -
Packets In 17.2K 0 -
Packets Out 14.9K 0 -
Current Connections 0 0 -
Maximum Connections 18 0 -
Total Connections 499 0 -
Min Conn Duration/msec - - 4.0K
Max Conn Duration/msec - - 6.0K
Mean Conn Duration/msec - - 4.0K
Total Requests - - 499
SYN Cookies
Status not-activated
Hardware SYN Cookie Instances 0
Software SYN Cookie Instances 0
Current SYN Cache 0
SYN Cache Overflow 0
Total Software 0
Total Software Accepted 0
Total Software Rejected 0
Total Hardware 0
Total Hardware Accepted 0
CPU Usage Ratio (%)
Last 5 Seconds 0
Last 1 Minute 0
Last 5 Minutes 0
Can you give me any clue? Thanks a lot!
