easyfan_179507
Apr 17, 2015[Help] Persistence Hash and Load Balancing together, Possible?
I know the request sounds weird... But it is true. Here is the thing:
We know that F5 supplied a persistence CARP hash since 10.0.0....
nitass_89166
Noctilucent
Apr 18, 2015But and additional request came in yesterday: for the request that does not match said pattern, sould be routed into pool member load balancing way. So I change the pool loading balancing method to "round robin", and change the iRule into:
why do you think it is not working? if result is not round robin, can you try to disable cmp?
sol14358: Overview of Clustered Multiprocessing (11.3.0 and later)
https://support.f5.com/kb/en-us/solutions/public/14000/300/sol14358.html
easyfan_179507
Apr 19, 2015BTW, I identify the response node by reading the node log.
