dyobbs_25515
Mar 29, 2012Help on Port Scan / SYN attack iRule
hi, do have an iRule that mitigates any source IP that runs port scanning and at the same SYN attacks? I tried to search but could not find any.
Objective is that once the malicious IP is detected, this gets dropped and logged. thanks!
- hoolio
Hi dyobbs,
I suggest contacting your F5 or partner SE on this scenario. They might be able to provide you with an interim solution and give you updates on future possibilities.
Aaron - dyobbs_25515
tnx hoolio..
