Help me to understand the HC - https_head_f5
Please help me to understand the default behavior of the health check - https_head_f5 which comes default in the LTM:
Especially on the send string :- HEAD / HTTP/1.0\r\n\r\n and receive String : Server:
It will be really helpful if i get an explanation with an output from LTM.
- amolari
the HEAD monitor sends a HEAD (instead of the classic GET, for the standard HTTP monitor) to the backend. Response from server won't include (MUST NOT, as per RFC) a message body. If you do not need the message body for your (simpler) status check, you can use that. It will save a little bandwith and server processing :-)
- amolari
curl -I "your_url" should make it (big cap "i" and not small cap "l")
