souravkayal_287
Aug 01, 2017Help for irule
set myIpH [format %08x $myIpE] set myIpD1 [expr 0x[substr $myIpH 6 2]] set myIpD2 [expr 0x[substr $myIpH 4 2]] set myIpD3 [expr 0x[substr $myIpH 2 2]] set myIpD4 [expr 0x[substr $myIpH 0 2]] set myIpD "$myIpD1.$myIpD2.$myIpD3.$myIpD4" log local0. "Server Ip address = $myIpD" node $myIpD 4244 unset myIpE unset myIpH unset myIpD1 unset myIpD2 unset myIpD3 unset myIpD4 unset myIpD unset unused
Want to know what does this mean and do. Sorry i am very new to irules.
- cjunior
Nacreous
This script part is within a context, so I will not alter or suggest any content here.
This way, I think this code snippet is related to a cookie persistence. See:
https://support.f5.com/csp/article/K6917So, I think this propose to do the following:
Given a cookie value: 1677787402.36895.0000 Catch IP address block myIpE: 1677787402 Convert value to Hex set myIpH [format %08x $myIpE] Result: 6401010a Catch Ip address octets set myIpD1 [expr 0x[substr $myIpH 6 2]] Result: 0x0a => 10 set myIpD2 [expr 0x[substr $myIpH 4 2]] Result: 0x01 => 1 set myIpD3 [expr 0x[substr $myIpH 2 2]] Result: 0x01 -> 1 set myIpD4 [expr 0x[substr $myIpH 0 2]] Result: 0x64 => 100 Concat to give the server IP address set myIpD "$myIpD1.$myIpD2.$myIpD3.$myIpD4" Result: 10.1.1.100 Write a log on the /var/log/ltm log local0. "Server Ip address = $myIpD" Result: Server Ip address = 10.1.1.100 Select node and port 10.1.1.100:4244 node $myIpD 4244 Dispose variables unset myIpE unset myIpH unset myIpD1 unset myIpD2 unset myIpD3 unset myIpD4 unset myIpD unset unusedI hope it helps.
Regards.
