yaoxu_11146's avatar
yaoxu_11146
Dec 10, 2008
help: can't find route to certain site via specified ISP connection
sorry if this is not the correct place to post this.
we have one F5 LTM box, with two ISP connections. we setup SNAT for some nodes and mapping their outgoing traffic to IP of ISP A. however we found one site on Internet is not reachable on these nodes. below is the tracert:
C:\Documents and Settings\usr>tracert cn.soap.search.msn.com
Tracing route to failoversoap.search.msn.com.cn.akadns.net [202.89.236.250]
over a maximum of 30 hops:
1 <1 ms <1 ms <1 ms 10.0.4.1
2 <1 ms <1 ms <1 ms 192.168.0.1
3 * * * Request timed out.
4 * * * Request timed out.
5 * * * Request timed out.
6 * * * Request timed out.
7 * * * Request timed out.
8 * * * Request timed out.
9 * * * Request timed out.
10 * * * Request timed out.
11 * * * Request timed out.
12 * * * Request timed out.
13 * * * Request timed out.
14 * * * Request timed out.
15 * * * Request timed out.
these SNAT nodes ARE able to access other Internet sites, and if we disable the SNAT, everything is fine.
It seems that the network package can't get out of internal network via ISP A's connection.
anybody has similar experience? where shall I take a look at? any advice will be apprecieated.
  • Sounds like you're missing a return route for the SNAT address. If you login to the upstream router can you ping the SNAT address and do other upstream routers know how to get back to the LTM?
