Help! - SCP Automated Backup file using Password
Hello Gentlemen,
I need to push the automated configuration backup files to a Windows server.
I tried this by copying the pub_key on to the destination server where this didn't work as the destination windows server is not supporting key based authentication.
The F5 LTM devices are running on TMOS version 11.4.1
I need to authenticate the destination server with password and I'm not sure if the automation script in place is working as expected, request your assistance.
Thanks for your help in advance!
Please find the code below:
! /bin/bash
var1=date
rm /automation/backup/*
devicename=F5LTM01_`date +%F`.ucs
tmsh save /sys ucs /automation/backup/$devicename
scp /automation/backup/$devicename [email protected]:/F5Backup
echo "Back up File copied to the Back Up Server(XX.XX.XX.XX) successfully to /F5Backup/ directory"
- Ryannnnnnnnn
Altocumulus
What about backing up to ftp and using something similar to the following:
!/bin/sh -x tmsh save /sys ucs /var/tmp/LTM_backup export a=`date +"%y%m%d"` export aa=$HOSTNAME.$a.ucs export b=/var/tmp/$aa mv /var/tmp/LTM_backup.ucs $b tar -cf /var/tmp/certs.tar /config/ssl export ff=$HOSTNAME.$a.certs.tar export f=/var/tmp/$ff mv /var/tmp/certs.tar $f export c=$HOSTNAME.$a.crontab export cc=/var/tmp/$c cp /etc/crontab $cc export MName=1.1.1.1 export Log=/var/tmp/log.bigip export UserName=SomeUserName export UserPassword=SomePassWord export Machine1f2=$aa export Machine1f3=$c export Machine1f4=$ff ftp -nvd ${MName} 14 <<-END 1>&2 > ${Log} user ${UserName} ${UserPassword} bin passive put ${b} ${Machine1f2} put ${cc} ${Machine1f3} put ${f} ${Machine1f4} quit END rm -f ${b} rm -f ${cc} rm -f ${f} RTN_CODE=$? exit $RTN_CODEYou can then configure a crontab entry and schedule backups for whenever suits you.
