Stephen_Winter
Cirrus
Jan 03, 2008Heath Monitor with in the Send String
Hi All,
Is there a way to imbed a in the send string? I have an application that likes the text separated that way and the BigIP doesn't support just pasting in a with the rest of the text...
I tried a "%9", but that didn't help...
Thanks.
-Stephen
- hoolio
\t should work.
Aaron - That does work. Thanks!
Was that in the docs somewhere that I missed?
Thanks Again!
-Stephen - hoolio
I was going off the examples that use \r for a carriage return and \n for a new line. I'm not sure what language the backslash escape control characters are from exactly though. They come into play with Perl and *nix shell scripting. Wikipedia (Click here) states it's a Computer Escape Code??.
Aaron - Deb_Allen_18Historic F5 AccountThis solution shows the escaped chars you can use in a monitor string:
SOL4186: Entering escape sequences in an ECV health monitor's send and receive strings (Click here)
HTH
/deb - hoolio
I hadn't seen that one. Thanks, Deb.
Aaron
