Health Monitors - Diff between Node default | Node Specific | None .
Hi F5 Team ,
What is the difference between Node default | Node Specific | None in Health Monitor settings while configuring the new node .
If you have got request to create a VIP and there is only one node behind it , which option do we need to select , When to use these settings .
- Vijay_E
Cirrus
In my opinion, there is no reason to monitor a node. Set it to "None" as we usually configure monitoring at pool member level.
None - no monitoring of node (IP)
Node specific - A specific monitor configure and used for that node.
Default - some common monitor used for all nodes based on your configuration.
You will see similar options for pool member monitoring too.
