Kimona_Robinson
May 04, 2015Health monitoring of node (not pool) used in Sharepoint iapp configuration
Can you add a health monitor to a node that is used in a Sharepoint iapp configuration (i.e. monitoring at the member/node level and not at the pool level?
- mikeshimkus_111Historic F5 Account
Nodes aren't managed by the iApp, so you can attach a specific monitor to a node w/o disabling strictness on the application service. In SharePoint, you don't have the option of not using a monitor on your pool, but the pool member status should follow the node.
Mike
- Kimona_Robinson
I created an HTTP monitor to attach to the node, however I'm not seeing it in the list of available monitors. What would be the cause of this can how can it be addressed? - mikeshimkus_111Historic F5 AccountThe types of monitors that can be assigned to nodes are limited. The list of available monitors on the node page are the only types available.
