Jessica_42876's avatar
Jessica_42876
Sep 28, 2011
Health Monitor
Hi, guys!
I have a problem with an F5 Health Monitor for Oracle with an OracleRac 11gR2 environment. We checked the next manual http://www.f5.com/pdf/deployment-guides/oracle-rac-database-dg.pdf to deploy the health monitor but it doesn't work. We make a trace and get the next error in the Oracle Listener:
ORA-12505, TNS:listener does not currently know of SID given in connect descriptor
Also, we checked the F5 logs in /var/log/ and we get the next message:
9/13/11 2:29 PM: jdbc:oracle:thin:@10.0.3.202:1522:oraculo(Thread-9070): getConnection (Io exception: The Network Adapter could not establish the connection)
9/13/11 2:29 PM: jdbc:oracle:thin:@10.0.3.206:1522:oraculo(Thread-9072): getConnection (Io exception: The Network Adapter could not establish the connection)
9/13/11 2:29 PM: jdbc:oracle:thin:@10.0.3.204:1521:oraculo(Thread-9068): getConnection (Listener refused the connection with the following error:
The Connection descriptor used by the client was:
The conclusion is: The F5 use the Oracle SID in the connection string but, with an OracleRAC enviroment, the SERVICE_NAME must be used instead the SID. Also, these connection string is an old fashion of the Oracle JDBC. So,what can we do?
and
can we use ". ", like such as an oracle.example.com in the Database?
Jessy
