Health Monitor Question
If we specify multiple URLs with “at least” condition, is it possible to prioritize the URL for health monitor?
i.e., if /health and /info both are provided with “at least” condition is it possible to configure /info to be of priority and if /info responds with 200, then do not bother pinging /health?
Thanks Ahmad
No. You can not prioritize. Conditions are either all or at least one.
- jaikumar_f5
Noctilucent
Like User: Only1masterblaster said, its all or atleast. Maybe you can try explaining your scenario.
You got 2 monitors,
- /health - Are you looking for any particular content or just 200 OK response.
- /info - Are you just checking 200 response here.
Guess if you properly put the receive string, you wont need 2 monitors unless there's any particular reason.
- SurgeonRet. Employee
You can apply 2 monitors or one but you can not set any priority on this. You can create your own external monitors and do your prioritization as you want
- mahmad2_222556
both health check URLs returning 200 OK. I just need to know if there is a way to prioritize health monitors may be using an iRule?
