health monitor question
I have a requirement from a customer where there are 2 members in a pool
172.16.197.204 port 22750 and 172.16.197.204 port 22760 .
First requirement is if URL is /solr/SPRUAT_Master then do Active / Passive load balancing between below nodes and traffic should only go to 172.16.197.204 port 22750 and I achieved that using priority group and a monitor as below
Send string GET /solr/SPRUAT_Master/admin/ping HTTP/1.0\r\n\r\n receive string OK
But in addition to that for same members as above they want
if URL is /solr/SPRUAT_Slave then do round robin load balancing between samew nodes as above.
How can i achive that using irule or something to make this work.
- giltjr
What I would do is define a new pool with both nodes and no priority group.
Then using an iRule examine the URI and select the appropriate pool.
when HTTP_REQUEST { switch -glob [HTTP::uri] { "/solr/SPRUAT_Slave*" {pool NewPool} default {pool ExstingPool} } } - Kirit_Patel_521
thanks . can't u define two monitors and use it in irule?
monitor 1
with receive string OK monitor 2
GET /solr/SPRUAT_Slave/admin/ping HTTP/1.0\r\n\r\n
with receive string ok
- giltjr
Any special reason you don't want to define a 2nd pool?
That I am aware of there is no way to "call" a monitor from a iRule and check the results.
- Kirit_Patel_521
no - no special reason have defined the irule as
when HTTP_REQUEST { switch -glob [HTTP::uri] { "/solr/SPRUAT_Slave*" {pool mhf_pool_172.16.250.72-slave} default {pool mhf_pool_172.16.250.72-80} } }
- Kirit_Patel_521
- Kirit_Patel_521
Ok its not working traffic is not going to pool pool mhf_pool_172.16.250.72-slave when i do the following.
Note I have a monitor setup for as sol_uat_slave where send string is
and recieve string is OK
^C$ telnet 172.16.250.72 80 Trying 172.16.250.72... Connected to 172.16.250.72. Escape character is '^]'. GET /solr/SPRUAT_Slave/admin/ping HTTP/1.0\r\n\r\n
HTTP/1.1 200 OK Connection: close Date: Sat, 18 Jul 2015 21:31:34 GMT Content-Type: application/xml; charset=UTF-8
03allsolrpingqueryfalseOK Connection to 172.16.250.72 closed by foreign host
Here is my full config
ltm pool /Finance/mhf_pool_172.16.250.72-80 { members { /Finance/172.16.197.204:22750 { address 172.16.197.204 priority-group 1 } /Finance/172.16.197.204:22760 { address 172.16.197.204 } } min-active-members 1 monitor /Finance/sol_monitor
sol_monitor is ltm monitor http /Finance/sol_monitor { defaults-from /Common/http destination *:* interval 5 recv OK send "GET /solr/SPRUAT_Master/admin/ping HTTP/1.0\\r\\n\\r\\n" time-until-up 0 timeout 16ltm pool /Finance/mhf_pool_172.16.250.72-slave { members { /Finance/172.16.197.204:22750 { address 172.16.197.204 } /Finance/172.16.197.204:22760 { address 172.16.197.204 } } monitor /Common/sol_uat_slave
my irule is ltm rule /Finance/sol_irule { when HTTP_REQUEST { switch -glob [HTTP::uri] { "/solr/SPRUAT_Slave*" {pool mhf_pool_172.16.250.72-slave} default {pool mhf_pool_172.16.250.72-80} }} }
- giltjr
Does the pool members for mhf_pool_172.16.250.72-slave show as up?
You may want to add:
log local0. "The URI passed was [HTTP::uri]"to the iRule just before the switch. That way you can verify that the URI is what you expect.
- Kirit_Patel_521
OK fixed the irule as
when HTTP_REQUEST { log local0. [HTTP::uri] if {[string tolower [HTTP::uri]] starts_with "/solr/spruat_slave" } { log local0. "matched [HTTP::uri]" pool mhf_pool_172.16.250.72-slave }
}But now I am trying add a OR statement and getting syntax error
01070151:3: Rule [/Finance/test_sol] error: /Finance/test_sol:3: error: [parse error: PARSE syntax 190 {syntax error in expression "([string tolower [HTTP::uri]] starts_with "/solr/spruat_slav...": unexpected operator &}][{([string tolower [HTTP::uri]] starts_with "/solr/spruat_slave") || ([string tolower [HTTP::uri]] starts_with “/sol”) }]
log local0. { "http::uri" [HTTP::uri] } if {([string tolower [HTTP::uri]] starts_with "/solr/spruat_slave") || ([string tolower [HTTP::uri]] starts_with “/sol”) } { log local0. "matched [HTTP::uri]" pool mhf_pool_172.16.250.72-slave }} - giltjr
Instead of using the double vertical bars (||) try using the word "or".
