health monitor issue from partition
Dears,
I have a strange behavior on my f5 BIG-IP (version 11.4.1) related to health monitor on nodes & pools. The f5 is partitioned into 3 partitions along with default common partition. Each partition has its own configuration and included default gateway and route domain. The problem is when trying to insert an external node into a pool as pool member and I choose health monitor type : TCP --> its not working (always offline in red) However ECHO-ICMP is working properly.
As well telnet from F5 cmd is not working within the pratition (rdsh X) however it works from F5 management.There is no asymmetric routing in our case and the f5 is placed one armed leg mode.
I tried to run wireshark on the node itself and discovered that the node is not replying back on SYN messages sent from F5 Partition IP.
Best Regards, Ralph El Habr
- Ilian_Ivanov
You can check what is your source IP address when trying to connect to the server.
"ip route get SERVER_IP" in bash mode. Just be sure that you are in the correct partition.
For example:
(bigIP)(cfg-sync In Sync)(Active)(/Common)(tmos) bash
[bigIP:Active:In Sync] ~ rdexec 2 bash
[bigIP:Active:In Sync:%2] ~ [bigIP:Active:In Sync:%2] ~ ip route get 1.1.1.1 1.1.1.1 via 10.10.10.1 dev eth0 src 10.10.10.71 cache mtu 1500 advmss 1460 hoplimit 64Then I can suggest you to check if that IP/Port are allowed on your FW. Have in mind that 10.10.10.71 is your self-IP, you will need to allow also the floating IP address (if you have one).
- aboulleill_3013
Dear Ilian,
Thank you for your prompt reply.But the firewall rules are allowing any any during troubleshooting purpose. I dont think its a firewall problem.
