Health check in body
Hello,
I am pretty new to F5 over all...:)
I need to create helth monitor which will check for body of the page and return 200 OK.
I tried below:
Send: GET /invoke/abc.Monitors.URL:urlMonitor HTTP/1.0\r\nHost:localhost\r\n\r\n
Received: 200 OK
But this is not checking in the body just i guess avilbility of the whole page (hopefully i am not mistaken) :)
I asked someone for help and they using curl get below output but still i have trouble...any help woul be approciated.
326001647:~$ curl -v
> GET /invoke/abc.Monitors.URL:urlMonitor HTTP/1.1
> User-Agent: curl/7.21.4 (universal-apple-darwin11.0) libcurl/7.21.4
>OpenSSL/0.9.8r zlib/1.2.5
> Host: abc.abc.net:5555
> Accept: */*
< HTTP/1.1 200 OK
Thanks in advance L.
- afedden_1985
Cirrus
I've seen a similar question here and maybe the same change will help you, 1st try changing your receive string> try just the number 200, thats what we use.
Our working monitor looks like this since our servers expect to see a host header,
HEAD /server/Healthstatus.asp HTTP/1.1\nHost: healthcheck.org \nConnection: close\r\n\r\n
another example we use without a host header is
HEAD /server/heartbeat.html HTTP/1.0\r\n\r\n
hope this helps - gargolek_116822
Thank you, this will be sending string but what would be receiving string, if health need to be based on body of html page?
Thank you in advance, - What_Lies_Bene1
The receive string needs to be something contained within the body that would only be present if the server/application was working. Your best bet is to get copy of the page source and discuss with the web/app team what the best string within it would be best to check for.
