Robert_47833
Altostratus
Mar 19, 2015hardware compression by LTM
in other post , it is said compression can be done via hardware or software. for Performance wise,compression should be done via hardware if huge throughout .
I want to know hardware compression here means some specific hardware card in Bigip?
how to check whether my LTM has this?
- amolari
here you have the information: sol13469: Determining the compression capability of your BIG-IP system (11.x)
- Robert_47833
Altostratus
if it is LTM 3900,can I purchase a AHA for hardware compression? or it is only avaiable for specific platform?
