Hard drive firmware upgrade
Dear All,
We're having an issue with our BIG-IP LTM 3900 in which we cannot backup/configsync our configuration file to the secondary box because of the below error:
Operation Status Saving active configuration... mkdir: cannot create directory `/var/tmp/cert_temp': Read-only file
Did anyone upgrade the Hard drive firmware successfully?
Also, During upgradation, all network cable should necessarly removed or that is only for EUD upgradatio?
Can you please share the steps you followed.
This error may or may not be indicative of a need to upgrade hard drive firmware, but doing an upgrade on 3900s won't hurt at all. It s a very painless process that is done from EUD and does not require removal of any cables - I have done it a number of times
- Amit03_165128
This is error under /var/log/ltm
err statsd[4087]: 011b0600:3: Error 'opening '/var/rrd/connections': Read-only file system' during rrd_update for rrd file '/var/rrd /connections'
And if I go for synchronization with the peer device I am getting the below error :
Checking configuration on local system and peer system... Peer's IP address: 172.24.0.1 Synchronizing Master Keys... Saving active configuration... mkdir: cannot create directory
/var/tmp/cert_temp': Read-only file system /tmp/cs_save_pre_script: line 70: cd: /var/tmp/cert_temp: No such file or directory tar: em/ssl.crt/5.5.5.5.crt: Cannot open: File exists tar: em/ssl.crt: Cannot utime: Read-only file system tar: em/ssl.crt: Cannot change mode to rwxr-xr-x: Read-only file system tar: em/ssl.crt: Cannot change ownership to uid 0, gid 48: Read-only file system tar: Error exit delayed from previous errors /tmp/cs_save_pre_script: line 77: cd: /var/tmp/cert_temp: No such file or directory mkdir: cannot create directory/var/tmp/cert_temp': Read-only file system /tmp/cs_save_pre_script: line 41: cd: /var/tmp/cert_temp: No such file or directory /tmp/cs_save_pre_script: line 61: cd: /var/tmp/cert_temp: No such file or directory mkdir: cannot create directory
/var/tmp/gtm_tmp': Read-only file system /tmp/cs_save_pre_script: line 105: cd: /var/tmp/gtm_tmp/gtm: No such file or directory /tmp/cs_save_pre_script: line 108: cd: /var/tmp/gtm_tmp/gtm: No such file or directory mkdir: cannot create directory/var/tmp/gtm_tmp': Read-only file system mkdir: cannot create directory
/var/tmp/em_db_temp': Read-only file system /var/tmp/cert_temp: Directory does not exist Error creating package Error running config sync all. BIGpipe parsing error: 01110001:3: Error running config sync all/var/tmp/gtm_tmp': Read-only file system /tmp/cs_save_pre_script: line 116: cd: /var/tmp/gtm_tmp/big3d: No such file or directory tar: client.crt: file changed as we read it mkdir: cannot create directory
