GUI management is going down about five minutes after restart th eunit
Hi ALl,
I have 1600 platform with 11.3.0 HF3 software. GUI management stops responding about five minutes after restart. Console and ssh is ok.
Did any of you had similar problem?
- Broda_146178
After another restart, situation is similar. - What_Lies_Bene1
A restart being a full box reboot?
Have you tried just restarting the http and tomcat processes?
bigstart restart httpd bigstart restart tomcatHave you tried increasing the maximum number of concurrent connections?
System > Preferences - Broda_146178
I have tried restarting httpd and tomcat. Did not helped. I found some article that it can be memory leaking in this version (11.3.0 HF3).
I thin I will try clean install...
- What_Lies_Bene1
Shame. If you can that would be ideal.
- Broda_146178
I will let You know about progress.
