KingMeow_3883
Altostratus
11 years agoGTM Multiple iQuery Connections to same LTM
I've noticed that GTMs typically have multiple iQuery connections going to the same LTM. Does this serve some kind of purpose? Are there different status updates from each IP in this case, or would the information just be getting duplicated across each connection?
- NikhilB
Employee
How did you establish your iquery session between the GTM and LTM? Perhaps the initial connection was torn down and new one created and possibly seeing remnants of it?
