rmd1023's avatar
rmd1023
Jan 25, 2013
gtm monitors running on ltm?
It looks like pool monitors to a generic host defined on a GTM will run from both the GTM and from LTMs it knows about. How do I limit where a monitor will run from so that a pool won't be marked as down because the pool member is unreachable from just one of my LTMs?
Thanks!
  • I just figured out if I create a Prober Pool with just my GTM's in it and set to "Global Availability" I can then configure that proper pool in the Generic Host server which appears to just allow the GTM's to monitor the Virtual Server in the Generic Host.
