GTM configuration synchronization problem
Hi, I've recently installed to new F5-GTM chassis and made them IN-SYN(Auto) as Active/Standby. When i define some setting on GTM-A, this setting is not duplicated on GTM-B(standby). So i have to apply gtm_add command make them synchronized.
note the fact that iQuery session has been establised successfully but i don't know how to make them IN-SYNC automatically.
Is there any idea about that?
- Andy_McGrath
Cumulonimbus
F5 DNS/GTM config sync is not the same as other modules and has a dedicated group.
So you do not need to setup a device group, like with say LTM, but instead simply use the
command to remove an F5 DNS/GTM local configuration, swap certificates to form a trust and copy the groups configuration locally.gtm_addSee the following for more details (based on v12) Adding a new BIG-IP DNS to a BIG-IP DNS Synchronization Group
