Luca_55898
Mar 26, 2013GTM - debug topology load balancing
Hi Guys.
I have setup some Wide IPs and am using Topology load balancing.
I have noticed that sometimes DNS requests don't hit the topology load balancing. Just wondering if there is any way to 'debug' topology load balancing so I can see whats really happening?
- Ferg_104721
Have a read on this
https://devcentral.f5.com/community/group/aft/1177240/asg/50
write an irule to make the selected region and log the info, either use an if or switch with an else/default to log catch data - Ferg_104721
Also may be useful
https://devcentral.f5.com/community/group/aft/1170857/asg/39 - Hamish
Cirrocumulus
There's not a lot available with regards to topology debugging that I'm aware of. I had similar issues, and the problem was the topology records themselves.
If you're attempting to do topology selection at the WideIP level, the target for the topology rule MUST be a Pool.
H
