arubio_6408
Mar 04, 2010Grid Control Pluging: error adding instances to monitoring
I have deployed the pluging with no errors.
I get the following error when I add the instance for monitoring:
Switch - em_error = ; nested exception is: javax.net.ssl.SSLHandshakeException: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
Any advice?
Thanks in advance
- arubio_6408
I've solved the problem.
I added the F5 certificate to the keystore of the agent (using keytool) and it worked. - Soujanaya_Sunku
I have the same issue , but i am calling the URL from Salesforce.
There is no way to import a certificate in to their Keystore.
How do i import it in to F5 Keystore?
