flomkrl_29950
Dec 07, 2007graph based on internal LTPM rra
Dear All;
I try to generate email report on the ltm.
I see that there is rra files on /shared/rrd.1.0 which are used (i think) to generate performance picture.
I try to generate graph without success with rrdtool graph tool.
Does anyone get rrdtool complete command line working with F5 rra file ?
I just want to get the performance picture and send them in my report email which is describe bellow
Thanks a lot,
Flo,
script to send report .
date > /tmp/statut.txt
echo -e "\n[BIG TOP]" >> /tmp/statut.txt
/bin/bigtop -once >> /tmp/statut.txt
echo -e "\n[FAILOVER]" >> /tmp/statut.txt
/bin/bigpipe failover >> /tmp/statut.txt
echo -e "\n[PLATFORM]" >> /tmp/statut.txt
/bin/bigpipe platform >> /tmp/statut.txt
echo -e "\n[VIRTUAL SERVER]" >> /tmp/statut.txt
/bin/bigpipe virtual >> /tmp/statut.txt
echo -e "\n[VLAN]" >> /tmp/statut.txt
/bin/bigpipe vlan >> /tmp/statut.txt
echo -e "\n[GLOBAL STATS]" >> /tmp/statut.txt
/bin/bigpipe global stats >> /tmp/statut.txt
echo -e "\n[DISK USAGE]" >> /tmp/statut.txt
df -ah >> /tmp/statut.txt
hostname=`hostname`
/bin/cat /tmp/statut.txt | mail -s "F5 $hostname status" [email protected]
- Colin_Walker_12Historic F5 AccountThere is actually a great document written and contributed by one of DevCentral's own members on graphing your BIG-IP's info that you might want to check out here - Click here
HTH,
Colin
