Geo-Location restriction using iRule for MS-Exchange
Description: in our environment the MS-Exchange has been integrated with F5 BigIP, and now deployed Geo-location to restrict the connection from any Geo-Location and only allow from the local GL while from the F5 can see two different type of traffic from MS-Exchange which are "active sync and OWA-Auth".
the Requirement: 1- Active-Sync - to be allowed from any Geo-location. 2- OWA-Auth; only to be allowed from US Geo-location.
I modified the following iRule but with no luck. when CLIENT_ACCEPTED {
Get the country client IP
switch [whereis [IP::client_addr] country] {
set allowed 1
default { set allowed 0 }
when HTTP_REQUEST { if { [string tolower [HTTP::uri]] equals "/***" } { if {$allowed == 0}{ drop HTTP::respond 403 content {Blocked!} } } }
your advice is highly appreciated!
- jaikumar_f5
Noctilucent
Did you check this article, it already have pre-define examples.
