Renato's avatar
Renato
5 years ago
Geneve tunneling for AWS GWLB
Hi!
We are trying to set up a Geneve tunnel between AWS GWLB and BIG-IP VE AdvWAF, but the BIG-IP is returning reset with cause "RST from BIG-IP internal Linux host".
Has anyone ever used this before?
Thanks!
Renato A. Ferreira
  • Hello Renato.
    This message is displayed when:
    "The BIG-IP system receives a RST acknowledgement (ACK) in response to terminating a service check."
    REF - https://support.f5.com/csp/article/K13223
    Have you checked that your self-ip is allowing that communication?
    REF - https://support.f5.com/csp/article/K17333
    I recommend you to follow this guidelines:
    https://techdocs.f5.com/kb/en-us/products/big-ip_ltm/manuals/product/bigip-tmos-tunnels-ipsec-13-0-0/1.html
    Regards,
    Dario.
    • forsan's avatar
      forsan
      I ran into this issue as well. I was running multi nic with this configuration:
      sys db provision.1nic value forced_enable
      set this to disabled.
      setdb provision.1nic disable
      This is a BUG.
      Br
      Andréas
  • Hi Renato,
    did you manage to integrate F5 and AWS GWLB?
    Br
    Andréas
