Sekhar's avatar
Sekhar
Feb 03, 2016
FTP issues using filezilla
We have recently setup VIP for ftp connections through F5. We are having issues when user is trying to access ftp using filezilla client (in both active and passive modes) . Is it possible that F5 is not able to handle connections coming from filezilla? Please help me in understanding this.
Thanks,
Sekhar
  • There is no incompatibilities with FileZilla that I know of. When you created the VIP did you apply an FTP profile?
    • Sekhar's avatar
      Sekhar
      Yes Brad, Session is timing out and I have tried allowing data-port 20 and 0. Both gave me same results. virtual config ltm virtual vs_test01_ { auto-lasthop enabled destination x.x.x.2:ftp ip-protocol tcp mask 255.255.255.255 partition Corp_Non-prod pool pl_test01 profiles { /Common/tcp { } ftp_test { } } source 0.0.0.0/0 source-address-translation { type automap } vs-index 92 } Thanks, Sekhar
    • Brad_Parker_139's avatar
      Brad_Parker_139
      What is timing out exactly? The opening of the control channel? The opening of the data channel? or is it timing out while a file is being transferred?
    • Sekhar's avatar
      Sekhar
      after initializing tls command on filezilla client time outs intially it retries again and fails.. this is the output on zilla client Status:Connecting to x.x.x.2:21... Status:Connection established, waiting for welcome message... Status:Initializing TLS... Error:Connection timed out after 20 seconds of inactivity Error:Could not connect to server Status:Waiting to retry... Status:Connecting to x.x.x.2:21... Status:Connection established, waiting for welcome message... Response:220-Welcome to FTP! Response:220 CrushFTP Server Ready! Command:AUTH TLS Response:234 Changing to secure mode... Status:Initializing TLS... Error:Connection timed out after 20 seconds of inactivity Error:Could not connect to server Status:Disconnected from server Thanks, Sekhar
    • Sekhar's avatar
      Sekhar
    • Brad_Parker's avatar
      Brad_Parker
      Icon for Cirrus rankCirrus
    • Sekhar's avatar
      Sekhar
