Satriaji's avatar
Satriaji
Icon for Cirrus rankCirrus
Aug 24, 2023
fqdn Pool member as IP VS in the same device or in the same 1 IP management or same box
Hii Everyone,
I have a  VS, snat automap, and using fqdn member that resolve dns in IP (10.1.1.x). Can I using the fqdn member (10.1.1.x),  as IP VS  in the same box or same ip management?? it can works ? If can'nt, what is the reason ??
Thankyouu so much ....
  • Hi Satriaji
    Are you saying you want send traffic from one virtual server to a FQDN pool member, that happens to also be a virtual server on the same BIG-IP?
    If so, there is a supported way to do that called Vip targeting Vip, and you use an iRule or a Local Traffic Policy to do that.
    • Satriaji's avatar
      Satriaji
      Hi JRam,
      Yeah, the VS that using the fqdn member, the fqdn member as IP VS in the same bigip.
      So, I have 3 VS. Called VS_A, VS_B, VS_C.
      The configuration is :
      VS A (IP VS : 10.1.1.x:443) member (a,b,c,d)
      VS B (IP VS: 10.1.1.x:80) member (a,b,c,d)
      VS C (IP VS: 172.x:80) member fqdn rmtools.hq.co.id that resolve (ip vs A & ip VS B 10.1.1.x) Using rewrite configuration.
      The rewrite configuration is :
      Type : Request
      Client URI : http://172.x/ (IP VS_C)
      Server URI : http://rmtools.hq.co.id/
      If the VS C created in the same box, its cannt running, but if the VS_C i create in the different box using same configuration, its works.
      How to resolve it ?
      The fqdn member resolve IP
      • JRahm's avatar
        JRahm
        Icon for Admin rankAdmin
        I'm not sure I understand what your goals are, and how this configuration is serving them. Can you take a step back and state your goals for each VIP and what traffic from what source needs to be managed?
