ndaems_145583's avatar
ndaems_145583
Nov 21, 2018
Forward to virtual and APM
I'm trying to define a Virtual Server as a Load-Balancer between multiple VS
Load-balancing is based on hostname
        if {[HTTP::host] contains "test.mydom.com" } {
                log local0. "Site Test 1"
                virtual /Common/vs_test.mydom.com
        } elseif {[HTTP::host] contains "test2.mydom.com" } {
                log local0. "Site Test 2"
                virtual /Common/vs_test2.mydom.com
                log local0. "SiteA"
Everything is working fine except that APM inside vs_test1 & vs_test2 are not applied
I'm able to connect to these VS without authentication
Is there any limitation or is it by-design?
Thank you
Nicolas
  • If you want APM to authenticate users, access profile must be assigned to the child Virtual server.
    Virtual server assignment may disable access profile on the parent virtual server.
