khairi's avatar
khairi
Aug 25, 2020
Forward specific URL to pool using LTM Policy
Hi All
I am still new with policy, I would like to forward traffic based on url path to specific pool. ex:
soa1.company.co.id/trackingnew_sb to Pool A
soa1.company.co.id/checktariff_sb to Pool B
I already checked on policy, I can not find action to redirect pool
Thank you
Regards
Labib
  • Hi khairi,
    Select action "foward traffic" under the section Do the following when the traffic is matched and after select your pool.
  • khairi's avatar
    khairi
    Hi Lidev
    Thanks for your response
    How about condition, I try to select "HTTP URI" , "PATH" , "/tracking_sb" as follows:
    Regards
    Labib
    • Lidev's avatar
      Lidev
      Your LTM policy condition is OK.
      If it's works, please don't forget to mark the answer as "the best" in order to pass your post as resolved, it helps others who ask the same question.
      Regards
