fix needed for ASM Web scraping attack
Dear Folks,
Here I am explaining the scenario what we are facing in our environment.
When user perform any activity in the applications, then Request is not going to the server. Requests has been caught in F5 and shows the Web scrapping attack.
Example: In F5, Requests attacks occuring here ->> /teamworks/ajaxCoach.
As this is local development environment, We need to customize the F5 filter for this issue. Please help to fine tune the rule for this kind of issues in order to get the response back without attacks.
Thanks, Anwar
- John_Buchanan
Does the URI follow a pattern of /teamworks/*? Have you added that as an allowed URL? Also could you share the details of the violation event? What does the User-Agent string look like? Are these requests coming in programmatically as the result of automated testing? Have you adjusted the thresholds for Web-Scraping detection, increased values for Bot Detection, Session Opening, and Session Transactions Anomaly?
- Anwar_csengg_25
Hi John buchanan,
Thanks for your answer.
I'm very new to this task
Please find my answer marked with bold for your questions
No (is this the way to allow ?Please suggest me i will do accordingly)
Yes. Please see the attachment
Are these requests coming in pro grammatically as the result of automated testing?
Request are coming through the development application
No.These all item values are set by default values.And Please advise me what i have to adjust or Increase the value for Bot Detection, Session Opening, and Session Transactions Anomaly
Thanks, Anwar
- Khay_164420Historic F5 Account
Hi Anwar,
I would strongly suggest you to first read this SOL: Web Scraping in 12.0 just to understand what Web scraping does and how the different features (bot detection, session opening, etc.) work.
Then, there are several ways to deal with these false positives:
- Adjust the thresholds in the Web Scraping configuration
- Whitelist the IP addresses in the Web Scraping configuration if there are well known IP addresses
- Remove the blocking flag for this feature (the security policy will be weakened then)
