CREDCO_17916's avatar
CREDCO_17916
May 07, 2008
"Fastest" load balancing question
What does BigIP use to determine the response times of each node in a pool, does it use the response time of the health monitor? Or does it use the response time of the web requests that it distributes among the nodes in the pool?
thanks
  • Well this depends on which Load balancing method is being used. I assume it's Predictive and Observed modes that specifically will interest you. Have you take a look at the following Click here
