BJ_114988's avatar
BJ_114988
Apr 07, 2015
Solved
Failover troubleshooting
how can i determine when did last failover happened and what caused it in LTM?
  • Havde you tried uploading qkview to https://ihealth.f5.com/?
    It's a good place to start looking for active/stanby time plus any other issues.
    You could also grep ltm logs for active/standby.
    zgrep Active /var/log/ltm*
  • M_2's avatar
    M_2
    You can also check with "show sys failover" command
    • SAM
