Failover Interface use case
Hello,
how can I configure failover interface in f5 5250v ? I am not sure how to use it for failover. Just to connect cable back to back is enough or something else we need to configure ?
I am running vcmp host and 4 guest in that box. Please suggest how can I effectively use this failover interface.
Hello ecoumesh,
If I understood correctly, you use one interface for normal usage, and you want to add a second one for every case(if the first one become down).
If you don't mind to use both of the interfaces simultaneously, you may try with trunk (portchannel).
I hope here you can find explanation:
Regards,
Preslav
