Luca_55898's avatar
Luca_55898
14 years ago
Failover event detected.... not sure why
Can anyone shed some light on the following logs:
We have two LTMs in a HA config. Not sure if the devices are actually failing over or not....
Mon Jul 11 11:48:24 EST 2011 notice local/LB003 sod[5151] 01140045 HA reports tmm NOT ready.
Mon Jul 11 11:48:24 EST 2011 notice local/LB003 sod[5151] 010c0050 Sod requests links down.
Mon Jul 11 11:48:25 EST 2011 info local/LB003 lacpd[5133] 01160016 Failover event detected. (Switchboard failsafe disabled while offline)
Mon Jul 11 11:48:25 EST 2011 err local/LB003 bcm56xxd[4993] 012c0010 Failover event detected. Marking external interfaces down. bsx.c(3276)
Mon Jul 11 11:48:25 EST 2011 info local/LB003 bcm56xxd[4993] 012c0015 Link: 1.15 is DOWN
Mon Jul 11 11:48:25 EST 2011 info local/LB003 bcm56xxd[4993] 012c0015 Link: 1.16 is DOWN
Mon Jul 11 11:48:25 EST 2011 info local/LB003 bcm56xxd[4993] 012c0015 Link: 3.1 is DOWN
Mon Jul 11 11:48:25 EST 2011 info local/LB003 lacpd[5133] 01160016 Interface 1.15, link admin status: enabled, link status: down, duplex mode: half, lacp operation state: down
Mon Jul 11 11:48:25 EST 2011 info local/LB003 lacpd[5133] 01160010 Link 1.15 removed from aggregation
Mon Jul 11 11:48:25 EST 2011 info local/LB003 bcm56xxd[4993] 012c0015 Link: 3.2 is DOWN
Mon Jul 11 11:48:25 EST 2011 info local/LB003 lacpd[5133] 01160016 Interface 1.16, link admin status: enabled, link status: down, duplex mode: half, lacp operation state: down
Mon Jul 11 11:48:25 EST 2011 info local/LB003 lacpd[5133] 01160010 Link 1.16 removed from aggregation
Mon Jul 11 11:48:25 EST 2011 info local/LB003 lacpd[5133] 01160016 Interface 3.1, link admin status: enabled, link status: down, duplex mode: half, lacp operation state: down
Mon Jul 11 11:48:25 EST 2011 info local/LB003 lacpd[5133] 01160010 Link 3.1 removed from aggregation
Mon Jul 11 11:48:25 EST 2011 info local/LB003 lacpd[5133] 01160016 Interface 3.2, link admin status: enabled, link status: down, duplex mode: half, lacp operation state: down
Mon Jul 11 11:48:25 EST 2011 info local/LB003 lacpd[5133] 01160010 Link 3.2 removed from aggregation
Mon Jul 11 11:48:35 EST 2011 notice local/LB003 sod[5151] 01140029 HA daemon_heartbeat tmm5 fails action is go offline down links and restart.
Mon Jul 11 11:48:35 EST 2011 notice local/LB003 sod[5151] 010c003e Offline
Mon Jul 11 11:48:35 EST 2011 notice local/LB003 sod[5151] 01140044 HA reports tmm ready.
Mon Jul 11 11:48:35 EST 2011 notice local/LB003 sod[5151] 010c0018 Standby
Mon Jul 11 11:48:36 EST 2011 info local/LB003 lacpd[5133] 01160016 Connected to failover service.
Mon Jul 11 11:48:36 EST 2011 info local/LB003 bcm56xxd[4993] 012c0012 Connected to failover service.
Mon Jul 11 11:48:36 EST 2011 notice local/LB003 sod[5151] 010c0048 Bcm56xxd and lacpd connected - links up.
Mon Jul 11 11:48:38 EST 2011 info local/LB003 bcm56xxd[4993] 012c0015 Link: 3.1 is UP
Mon Jul 11 11:48:38 EST 2011 info local/LB003 bcm56xxd[4993] 012c0015 Link: 3.2 is UP
Mon Jul 11 11:48:39 EST 2011 info local/LB003 bcm56xxd[4993] 012c0015 Link: 1.15 is UP
Mon Jul 11 11:48:39 EST 2011 info local/LB003 bcm56xxd[4993] 012c0015 Link: 1.16 is UP
Mon Jul 11 11:48:40 EST 2011 info local/LB003 lacpd[5133] 01160009 Link 1.15 added to aggregation
Mon Jul 11 11:48:40 EST 2011 info local/LB003 lacpd[5133] 01160009 Link 1.16 added to aggregation
Mon Jul 11 11:48:40 EST 2011 info local/LB003 lacpd[5133] 01160009 Link 3.1 added to aggregation
Mon Jul 11 11:48:40 EST 2011 info local/LB003 lacpd[5133] 01160009 Link 3.2 added to aggregation
