Failover cable
All,
I'm in the process of designing a move of a pair of LTM's to a seperate location in our DC - it's roughly 3.5 metres away.
I'm wondering if this scenario would work - unplug failover cable, move secondary F5 to new location then attach a 3metre RS232 cable to the now primary F5 unit and then do a force to standby and proceed to move the secondary system.
so to summarise - would a RS232 to RS232 cable work as a failover cable as a temporary measure?
Thanks for your assistance.
Thomas.
- Thomas_McLean_1
Sorry I think I'm confusing myself here - would a normal serial cable work? - What_Lies_Bene1
I think so;
The F5 BigIP failover cable pinouts are as follows;Pin Pin DTR 4 6 DSR SG 5 5 SG DSR 6 4 DTR RTS 7 8 CTS CTS 8 7 RTS
The maximum recommended length is 50 feet (approximately 15meters.) - Thomas_McLean_1
Thanks for that What Lies Beneath! Now lets hope everything goes smoothly at the weekend mate :) - What_Lies_Bene1
You're welcome. Good luck. - What_Lies_Bene1
Note: Where possible, Connection, Persistence and SNAT mirroring should be used to minimise the effects of failover and failback on client connections and traffic flow. - Thomas_McLean_1
Posted By What Lies Beneath on 02/07/2013 02:42 AM
Note: Where possible, Connection, Persistence and SNAT mirroring should be used to minimise the effects of failover and failback on client connections and traffic flow.I shall check that right now - but I'm sure when setting this up I done the above but best do it for sanity purposes really.
Cheers agan and thanks for the add!
- What_Lies_Bene1
Cool. Anytime.
