F5 VE Trial and integration to GTM
hi, has anyone experienced the issue of getting GTM running BIG-IP 10.2.4 Build 732.0 Hotfix HF5 to install big3d on the virtual trial version?
192.168.18.200 is the trial ltm. bigip_add runs no problem. the big3d process is not running on the trial ltm..
thanks in advance
[root@BIGIPl:Active] config big3d_install 192.168.18.200
Making sure all BIG-IP systems can be reached, and
checking kernel and big3d versions on each BIG-IP.
Gathering big3d info from 192.168.18.200
Attempting via iqsh ... Connection to ::ffff:192.168.18.200:4353 failed: Connection refused
Unable to retrieve version and platform information via iqsh for 192.168.18.200
Attempting via ssh ...
Password:
bash: /usr/sbin/big3d: No such file or directory
Unable to retrieve bigpipe and/or big3d versions from 192.168.18.200
There is 1 system that could not be reached.
There are multiple reasons that this can occur, including:
- The network connection to the system is down.
- The system is down.
There are no reachable systems to install big3d on.
Exiting
[root@BIGIP:Eval:Active] config [root@BIGIP:Active] config bigip_add 192.168.18.200
Retrieving remote and installing local BIG-IP's SSL certs ...
Enter root password for 192.168.18.200 if prompted
Password:
==> Done <==
[root@BIGIP::Active] config
also, big3d installs on the ltm no problem:
