F5 VE latency and sync issues
We recently moved our two F5 VE Lab appliances from an older VMware 5.1 environment to new host with 5.5. Since that move we have not been able to get the devices to sync and are also seeing higher than normal latency when pinging Self-IP's on the F5's. Both VM's are running 11.6.
Whenever you try to sync the two you always receive " did not receive the last sync successfully". While monitoring /var/log/ltm you can see the peer connection drop then re-establish and also a message constantly coming up with "Bandwidth utilization is 8 Mbps, exceeded 75% of Licensed 8 Mbps".
Another thing that is noticed is with latency while pinging Self-IP's from the F5 and to it. Even when both VE's are on the same host and ping each other's peer IP address we see 1-2ms, if you raise the MTU size up that starts going up. When using a 1500 MTU it goes up to 5-6ms, when using 9000 (9000mtu is enabled) it goes up to 70-80ms.
I have built new VM's from F5 OVA image and re-licensed but the two new ones still see the exact same issue. I built an Ubuntu VM and put it on the same host and peer IP VLAN it has NO problems. If I use the Ubuntu host to ping the peer IP on each F5, all on the same VLAN, I see the latency with the F5.
Any thoughts are suggestions would be much appreciated. Thanks.
UPDATE:
Noticed this from both VM's as well, one is receiving the sync other is sending
[root@LAB-F5-1:Standby:Awaiting Initial Sync] config tmctl -d blade tmm/if_shaper
shaper_tid ingress_max ingress_avg ingress_red ingress_drops egress_drops
5 2687 100 0 0 0
4 2771 100 0 0 222
6 2687 100 0 0 0
2 2936 100 0 0 0
3 2687 100 0 0 0
7 2771 100 0 0 389
1 2771 100 0 0 193
0 2771 100 0 0 70
[root@LAB-F5-2:Active:Awaiting Initial Sync] config tmctl -d blade tmm/if_shaper
5 2808 100 0 0 0
3 2559 100 0 0 0
4 45751 99 207 142 0
7 44484 99 135 87 0
1 42022 99 160 116 0
2 2559 100 0 0 0
6 45027 99 73 49 0
0 39703 99 62 51 0
- Hannes_Rapp
Hello, Corey
It appears you have two issues, one with syncronizing the cluster, another with poor Latency. If you have an active Support Contract for those appliances, I would highly recommend to open an official Support Case. Any remote troubleshooting with no direct access to your system will take more time than needed. Regardless, you will most likely be able to resolve the Config Sync issue by yourself, please refer to this article to get you started with troubleshooting Config Sync issues: https://support.f5.com/kb/en-us/solutions/public/13000/900/sol13946.html.
