pasan_239927's avatar
pasan_239927
Jan 17, 2016
F5 VE lab setup question - Load balancer not responding to VIP?
hi,
Being quite new to F5, I am trying to setup my F5 practice lab according to: https://devcentral.f5.com/articles/configuring-the-big-ip-and-php-hack-it-yourself-auction-site
I have changed the IP addresses aroudn to match the F5 training manual -"Configuring BIG-IP ASM v11 Application Security Manger" (v11.6.0 - December 2014), and I am running the F5 virtual lab edition 11.6.
So far it's been good and I could access the GUI and configure the setting okay.
a. I have setup a virtual server with the IP address of 10.10.36.10 as shown below:
b. The vlan interface called "External" has also been setup okay:
    external  Link encap:Ethernet  HWaddr 00:0C:29:F3:A9:81
              inet addr:10.10.36.31  Bcast:10.10.36.255  Mask:255.255.255.0
              inet6 addr: fe80::20c:29ff:fef3:a981/64 Scope:Link
              UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
              RX packets:6547 errors:0 dropped:0 overruns:0 frame:0
              TX packets:76 errors:0 dropped:0 overruns:0 carrier:0
              collisions:0 txqueuelen:0
              RX bytes:928727 (906.9 KiB)  TX bytes:3512 (3.4 KiB)
c. from my test machine (10.10.36.200), I can access the F5 GUI via this external interface(10.10.36.31) without any issues (as I have allowed this over 443)
d. The vlan interface named "Internal"(which connects to the test web server I have setup) has also been setup okay:
    internal  Link encap:Ethernet  HWaddr 00:0C:29:F3:A9:8B
              inet addr:172.16.36.31  Bcast:172.16.36.255  Mask:255.255.255.0
              inet6 addr: fe80::20c:29ff:fef3:a98b/64 Scope:Link
              RX packets:26595 errors:0 dropped:0 overruns:0 frame:0
              TX packets:34891 errors:0 dropped:0 overruns:0 carrier:0
              RX bytes:25210162 (24.0 MiB)  TX bytes:2108852 (2.0 MiB)
e. The test webserver("hack it auction site") connects via this "Internal" vlan. And communications between the BIG IP and this webserver is okay as shown here:
[root@bigip36:Offline:Standalone] config  tcpdump -i internal
-snip-
22:37:41.436510 IP 172.16.36.31.59490 > 172.16.36.150.http: R 209840290:209840290(0) win 0
22:37:41.438002 IP 172.16.36.150.http > 172.16.36.31.59490: . 2897:4345(1448) ack 10 win 181
22:37:41.439017 IP 172.16.36.31.59490 > 172.16.36.150.http: R 209840290:209840290(0) win 0
22:37:41.440543 IP 172.16.36.150.http > 172.16.36.31.59490: . 4345:5793(1448) ack 10 win 181
22:37:41.441510 IP 172.16.36.31.59490 > 172.16.36.150.http: R 209840290:209840290(0) win 0
22:37:41.443001 IP 172.16.36.150.http > 172.16.36.31.59490: . 5793:7241(1448) ack 10 win 181
[root@bigip36:Offline:Standalone] config  telnet 172.16.36.150 80
Trying 172.16.36.150...
Connected to 172.16.36.150.
Escape character is '^]'.
f. However, the F5 does not seem to respond to the VIP I have setup.. although I have made sure the traffic is reaching the F5 machine via a static route on the test client(10.10.36.200):
[root@bigip36:Offline:Standalone] config  tcpdump host 10.10.36.200 -i external
tcpdump: verbose output suppressed, use -v or -vv for full protocol decode
listening on external, link-type EN10MB (Ethernet), capture size 96 bytes
22:43:11.127120 arp who-has 10.10.36.31 tell 10.10.36.200
22:43:11.127151 arp reply 10.10.36.31 is-at 00:0c:29:f3:a9:81 (oui Unknown)
22:43:11.130201 IP 10.10.36.200.50310 > 10.10.36.10.http: S 2503420874:2503420874(0) win 8192
22:43:11.377807 IP 10.10.36.200.50311 > 10.10.36.10.http: S 1615593643:1615593643(0) win 8192
22:43:14.127824 IP 10.10.36.200.50310 > 10.10.36.10.http: S 2503420874:2503420874(0) win 8192
22:43:14.378025 IP 10.10.36.200.50311 > 10.10.36.10.http: S 1615593643:1615593643(0) win 8192
22:43:20.286651 IP 10.10.36.200.50310 > 10.10.36.10.http: S 2503420874:2503420874(0) win 8192
22:43:20.378197 IP 10.10.36.200.50311 > 10.10.36.10.http: S 1615593643:1615593643(0) win 8192
22:44:55.886515 IP 10.10.36.200.netbios-dgm > 10.10.36.255.netbios-dgm: NBT UDP PACKET(138)
Wireshark cap from the client machine:
The F5 simply doesn't seem to response.. Out of interest I tried accessing the vip from the F5 itself and I get:
[root@bigip36:Offline:Standalone] config  telnet 10.10.36.10 80
Trying 10.10.36.10...
telnet: connect to address 10.10.36.10: No route to host
  • Am I supposed to add a route in addition to defining the virtual server as I have mentioned above?
  • What could I be doing wrong here?
Kindly,
Pasan
  • The device shows as 'offline'. Can this be the cause?.. If so how can I set it to become active in this lab environment?
  • It seemly I completely missed the fact the device was working offline. Since it's first time setting this up, thought that's norm. for the virtual environment :) learnt that traffic management won't work when the device is not active, even though you can access the GUI, ping and all
    Trying to figure out why the device was inactive, it was show the 'HA status' as down. I wasn't sure how to bring that up so rebooted the device and the HA status became 'Active' again. Seems it synced with the 'device_trust_group'.. which I am not really sure what that's referring to:
