F5 shellshock with Bash shell.
I check in my F5 with command: env x='() { :;}; echo vulnerable' bash -c 'echo this is a test' and I receive result: vulnerable this is a test Thus, my system is vulnerable.
I read links: https://devcentral.f5.com/articles/shellshock-mitigation-with-big-ip-irules But, i read links: https://support.f5.com/kb/en-us/solutions/public/15000/600/sol15629.html I want to know this link is solving this problem bash vulnerability? Pls guide me to solve this problem bash vulnerability.
Add Comment
- samstep
Cirrocumulus
SOL15629 is what you need if you are concerned with Shellshock in F5 Management Advanced Shell.
Latest hotfixes are avilable which patch the bahs vulnrability - simply patch your F5 with the latest hotfix for your version:
11.6.0 HF1 11.5.1 HF5 11.5.0 HF5 11.4.1 HF5 11.4.0 HF8 11.3.0 HF10 11.2.1 HF12 10.2.4 HF9
Sam
- nathe
Cirrocumulus
luyenntk50db,
The iRule is for backend servers that might be vulnerable that are fronted by a big-ip device. The big-ip, via an irule, can prevent the attack vector from reaching the backend servers. This gives you time to patch them.
Sol15629 details the big-ip TMOS versions that are vulnerable, namely the management web gui. If you haven't patched to the non-vulnerable release then you will be vulnerable. Of course bear in mind that, as of a couple of weeks ago, the only exploit was an authenticated one, i.e. an attacked would need admin/root access to the big-ip. Further recommendation is to keep the management network on a private, secure network and if there any any self IPs which are externally accessible then disable 443 access.
Hope this helps,
N
- luyenntk50db
Now, Big-IP OS is 10.2.1; can i upgrade from 10.2.1 to Hotfix-BIGIP-11.6.0.1.0.403-HF1? i read link below: https://support.f5.com/kb/en-us/solutions/public/9000/500/sol9502.html I think that, i have to upgrade from OS 10.2.1 to 11.6.0 BIG-IP Release. And then, i will patch 11.6.0 BIG-IP Release with Hotfix-BIGIP-11.6.0.1.0.403-HF1. Pls guide me.
